Re: Would running exrta TCW 3 oil damage engine ?
Scali- <br />Depending on the oil ratio you choose- Short term you will see the obvious- more smoke, fouled plugs, and potentially poor idle (plug fouling). Long term, you will see excessive carbon build up and the potential to stick a ring due to that carbon build up. Decarbing with SeaFoam will be a regular project. <br /><br />It is possible that you could see less carbon build up by using a synthetic, but its still going to be an issue. <br /><br />I agree with Chief 101, Since you are planning on doing some premix anyway, if you are that worried about it, why not just bypass the oil injection and just use the premix as your primary lubrication?<br /><br />If you aren't WOT very often and just cruising, you probably are not using that much fuel to make premixing that big of deal for you...<br /><br />Good luck!
