would you run this crankshaft?
J JACKSON
it measures within spec but its not a really smooth finish i don't know if you can tell from the pictureIMG-20140322-00252.jpg
175se
Re: would you run this crankshaft?
close your eyes, run your fingernail across it can you feel it? if you can so can the bearings, in that case I myself wouldn't use it.
J JACKSON
you can't feel it but it has the appearance of a bearing race that is starting to go little fractures in the finish, looks like a lobe on a camshaft that's starting to wear off
175se
did it come off an engine that sat for long period, or had water intrusion? You could try to polish it with some crocus cloth, it might remove the discoloration and give you a better look.
J JACKSON
no it started knocking the rod was ruined, I am going to bring it to a crankshaft to a crankshaft rebuilder Monday and have them look at it
These cranks are hardened.-------They are part of a roller bearing set-up.------You can not buy O/S rollers if you grind it down.----Only a few specialized shops claim to repair outboards cranks.
Faztbullet
I would not run it until it was inspected and polished. If your not in a hurry PM me....
