trobinson017
- Joined
- Sep 12, 2004
- 183
Holy cow! I've been posting to iBoats for a couple years now and never knew there was a Seaswirl specific forum! Sigh, that's about the same luck I have fishing; I find 'em once every couple years.
Anyway, I have a 1999 21' Seaswirl Striper CC with a Johnson 130 Oceanpro outboard. I actually bought it in 2003 as a new boat, first owner. The boat was in a Texas holding facility cuz the dealer there was filing for bankruptcy. It was released from holding in 2002 and bought up by a dealer here in Florida. I then bought it from the dealer in 2003.
I've had a lot of problems with both the boat and the motor. Most are/were minor but annoying. My biggest issue thus far has been water in the bilge area. I'm still working that out and it's getting better as I discover, remove or fix things. I should say this is my first boat so I'm still learning. I've only had to call SeaTow twice.
One major question I have is about the oil injection system. Does anyone else use this? I'm not really sold on it. For one, with two batteries installed I can't see the level in the oil tank, so I have to guess how much is needed (no gauge). Also, I'm concerned about the injection pump failing and not getting a warning alarm. What is the consensus on this? Do most who have it still use it? Or have many of you that had it removed it in favor of mixing the oil in yourself? I'm leaning toward removing it.
Anyway, even with it's problems it's still a boat that gets us out on the water. As a matter of fact, the tides up high enough now so I can float it off the lift.
With that, I bid you all "later" and glad to have found this forum!
