Wow!! From underneath, the surface of the lake looks so close,,,,,,,
Winger Ed.
Last week, I went out with Hooty for a bit of high speed boating. Or, so I thought when we made the plans.<br /><br />The wind was gusting, and after launching, I noticed the waves were running about 2' high*** and white capping.<br /><br />***<br />In the new hydro, your butttt is about even with the water's surface, and the bottom of the hull is pretty much flat. So, in rough conditions, keeping the nose of it up is rather important.<br />**** <br /><br />No problem, I thought. We'll just get over to the other side where the cliffs block the wind. The water will be flat, and I can test my new settings and hi-tech 26" Chopper prop. <br /><br />In doing so, I tried to keep the nose up, that meant that at about 30mph,,,, only the last 6-8 inches of the top of EVERY!!! wave or swell was chopped off and sent straight into my face. This is while you're taking a pounding that would push the average size hemoroid up under your eyebrows. <br /><br /><br />Much to my relief, Hooty finally came around and passed me, as he hugged the shore I was trying to get to.<br /><br />As he passed, I swung in behind him. I figgered his boat would flatten the water a bit.<br /><br /><br />So, I pulled in behind him and punched it....<br /><br />All I remember is feeling the prop bite, the normal sensation of acceleration where your sunglasses try to become contac lenses, and seeing the tach go past 5000. Which is about 70mph.<br /><br />Then,<br />Before I could react, and get off the 'go' pedal, There was a 'rough' wave about a foot tall at eye level and right in front of me..... Then I was on it. <br /><br />About a millionth of a second later, I was airborne, but still accelerating over the top of that wave like a motorcycle making a jump.<br /><br />Then, before that millionth of a second had passed,,,,,,, the boat stopped its verticle assent, tipped over, and nosed in. Shortly thereafter, I was looking up at the surface of the lake, feeling my life vest pulling me up and out of POCO LOCO.<br /><br />WOW!!!,,, WHAT A RUSH!!! <br /><br />At this point, my sunglasses had departed the Airframe. But while they pushed back hard enough to bruise my smooth, delicately complected forehead,,,, they did keep the water from going up under them around the corner, and blasting up under my eyelids.<br /><br /><br />In that instant, I looked up and saw the surface of the lake...... I figured the front of the boat had about 5,000 pounds of bouyancy, and since we were coming up so fast,,,, I just held my breath and hung onto the steering wheel rather than relax and let myself be lifted out. <br /><br /><br />I don't know how deep we dove, but I do remember it seemed to get darker and darker before I saw it getting more and more bright as me & the boat changed direction and were pulled up and closer to the Sun. The 150 Merc. V-6 flipped up hard enough to crush the top cowling and destroy the fwd. cable of the twin cable steering system. That's when I think the overtilt mercury switch shut it off. I wonder if the engine wasn't so healthy and with such high compression, it wouldn't have rotated a few more times rather than coming to rest as it did. I think with 3 or 4 more revolutions of the crankshaft- it would have sucked in a bit of Lake Grapevine in the process, and destroyed itself. <br /><br />Anyway;<br />On the downstroke, the weight of the engine coming down so hard & fast ripped the transom about half way off. The top braces going from the transom to the frame of the boat made from 1/4" Al. bar stock were torn apart at their mounting holes. <br /><br />But;<br />After coming to rest....more or less above the level of the lake.... The cockpit and my lap was filled level full with water, I heard both bilge pumps come on and empty it in about a minute or 2. <br /><br />Then, after gathering my wits, I hit the key and and that bad boy Merc. fired right up and brought me back to the dock.<br /><br />///////<br /><br />I could go on with a few more details, but my hands are starting to shake a bit much as I realize how lucky I am.<br /><br />I have to stop and appreciate the fact that God really does love old Marines.......<br /><br /><br />,,,Lots of guys have done what I did, not even going as fast as I did,,,,, but they didn't survive the experiance. <br /><br />S/F,<br />SSGT Ed.<br /><br /><br />But, then again,,,,,,,<br /><br />WOW!!<br />What a Rush,!!!!,,,,,,<br /><br />If it wasn't so hard on the boat,,,,, I'd sort of like to do that a couple more times..........
Dunaruna
Re: Wow!! From underneath, the surface of the lake looks so close,,,,,,,
Glad you're o/k. <br /><br />I don't know if you wrote your post with this intention but I 'felt' the rush as I was reading.<br /><br />Never a waterproof camera around when you need one :eek: <br /><br />Aldo
Winger Ed.
Originally posted by Dunaruna:<br /> Glad you're o/k. <br /><br />I don't know if you wrote your post with this intention but I 'felt' the rush as I was reading.<br /><br />Never a waterproof camera around when you need one :eek: Aldo
Thanks buddy.<br /><br /><br />All my life, I've tried to teach, and pass on to others what little bit I know. Glad it came through this time.....<br /><br />When I (sort of)designed and built this boat, I made it so the driver could get out easily. Its like a go-kart, there is nothing over your legs, and the cockpit is totally open at the top. <br /><br />I made it so the driver would get tossed out into right field several yards before it flipped over in a HARD !! turn at speed, and could possibly trap him. Or, if it 'kited' or tried to flip over backwards, the driver could look down, and watch the hull turn over & splash before he fell back into the water as the forces of gravity and momentum had their way with the boat & driver.<br /><br />However;<br />I never considered plunging it straight down into the water at speed. In that respect, as you can see in various photos--- there is nothing keeping that force of the boat entering solid water at high speed from breaking the driver's neck. <br /><br />Ed.
TwoBallScrewBall
Holy crap. Go buy a lottery ticket buddy. :)
Boomyal
Incredible story WE. Sure glad you're ok.
sangerwaker
No doubt, you are a very lucky man. Glad to hear you are OK. Bummer about the boat.
jtexas
Well-told, Ed! Glad you survived. Wasn't there a Bond movie with an airplane/submarine conversion vehicle?<br /><br />Let us know when you get that bad boy ready for another test flight, I'll be glad to show up & stand by in case of emergency. Heck I'll even film it (you'll have to supply the camera, though, sorry).<br /><br />jtw
Barlow
Holy crap Ed! ...First, I'm glad you're OK bud! <br /><br />uh... I'm glad you're ok .<br /><br /><br />.... I really want to throw some sarcasm out on the table but,.... I just can't do it.<br /><br />Keep us posted on the repairs.<br /><br />It's good to have you around here. ;)
Twidget
Yikes, glad you're ok.
cbnoodles
Cool! Sorry about the boat though. Build a 2-seater next time & take me with you!
Winger Ed.
Originally posted by The Professor:<br /> Cool! Sorry about the boat though. Build a 2-seater next time & take me with you!
Thanks guys..<br /><br />I actually started off building it to be a 2 seater. However, no one I know--- especially the wife--- would agree to ride in it. And they were all very adament about it too. So, I just brought the cowling all the way up to the back of the driver's seat, and put the fuel tank behind it.
Dunaruna
Did it look like this just before...........
lawyertob
WE, I was a Submariner in the Navy. I know that alot of the Jarines...I mean Marines ;) used to say that we were crazy for sinking a perfectly good ship. The thing is that our boat was DESIGNED to sink and come back up...unlike the tin cans they hauled the Marines around in...they usually just sink once.<br /><br />That being said, I am not going to go into how crazy a person has to be to driving a little hydro like yours in 2 foot whitecaps...<br /><br />I am glad you made it...and I look forward to reading some more of your posts...they are usually informative and helpful...but don't EVER ask me to go for a boatride with you ;) <br /><br />Just my $0.02 worth,<br />Joe
Mr.Ladyfish
Heck of a story WE. Glad you made it without an ambulance ride.<br /><br />There ain't enough beer in the world to get me to ride with you. :D
Winger Ed.
I am not going to go into how crazy a person has to be to driving a little hydro like yours in 2 foot whitecaps...<br /><br />Joe [/QB]
Thanks buddy,<br /><br /><br />--- I hear ya. But I wonder if a guy used to tooling around 500' or so under the Ocean for about 3 freaking months at a time is really qualified to lecture me on the pros and cons of (trying to) riding over 2' whitecaps.....LOL <br /><br /><br />Although Submariners are my favorite class of Chain Greasers,,,,,,,<br /><br />I'm still dismayed at their lacking very much of a sense of adventure.... Har, har, har,,,,<br /><br /><br />Welcome to Iboats, and I hope to hear from ya more.....<br /><br />Ed.
lawyertob
Hehe...yeah, there is a little bit of a pucker factor the first time you ride one down to test depth. ;) But the old saying is true: There are two types of ships on the ocean - submarines and targets. :) I always felt safest when I had a good layer of water and preferably ice over me.<br /><br />Anyway, glad you survived, and I can't wait to see the pics. I assume that you will be rebuilding? <br /><br />Another $0.02 worth,<br />Joe
Barlow
Ok, remember I didn't start this Ed ..<br /><br />When I first saw your Hydro and noticed you're a Texan .. I had my thoughts. LOL<br /><br />-THEN- Another variable was added - You're an ex-Marine!! <br /><br />Let's review ....<br /><br />- Ex-Marine<br />- Texan<br />- Hydroplane<br /><br /><br />...I will say no more .. :p :D
Winger Ed.
Oh yeah. All I need to replace is one of the top braces that hold the top of the transom to the frame. The transom is at a different angle than it started out, but I like it that way better anyway. The top cowling can be jacked back up where it looks rounded again, and replacing a dozen rivets that blew out isn't a big deal. Changing the fwd steering cable and the tube it rides in shouldn't be a big deal.<br /><br />I'm done for this year though. I've got the garage tied up building a cabinet for the new wife's antique dolls...... Yeah, its hard for me to believe too..<br /><br />When I get it done, I'll move the hydro back inside. When I take the eng. off to work on the transom, I'll send the heads out to be cut at the same time. With a few more horsepower, I may be able to get into more trouble.....<br /><br />Somewhere in between all that, I'll do the little bit to get the old Al. 21' day cruiser tidyed up and hopefully put it down on Lake Whitney for the winter & spring. <br /><br />Ed.
Winger Ed.
Originally posted by Barlow:<br /> Let's review ....<br />- Ex-Marine<br />- Texan<br />- Hydroplane
OK now Cheesehead....... <br />I'm sure that be much more funny after I've had a few more beers and a big chit'lin dinner.......
