PiratePast40
Thread starter- Joined
- Mar 21, 2009
- 1,734
Picked up a used bellhousing for my Volvo AQ130D w/ 280 outdrive since the old one had been destroyed by the u-joint knuckles. After replacing the bearings and seals, noticed that there were different snap ring grooves in the housing itself and that the shaft seals were not up against the bearings. Here's the picture to show you what I mean:
The bearing is on a set position on the shaft. The shaft can be placed all the way in so that the bearing race sets on the shoulder just above the inner seal and then held in place by the outer snap ring OR a snap ring can be placed in the lower groove and the bearing placed on that ring with the outer seal and then snap ring placed outside of that. In either position, one of the seals would be about 3/4" away from the bearing.
With the shaft in the outer position, the inner end of the shaft extends below the bellhousing about 1/8". This just barely allows the shaft to set inside the crankshaft bearing about 1/8" so this position doesn't make sense.
If the shaft is placed all the way in, the outer snap ring just keeps the seal from coming out but also allows a 3/4" gap between the seal and bearing. Also, in this position, the engine side of the shaft seems to be allright and the splines don't quite make it all the way through the U-joint yoke.
I'm now at the point of not being sure that this is the correct bellhousing. This bellhousing bolts up fine to my pushrod motor but the positioning of the grooves is suspicious to me. The only external differences in the bellhousings were that there was a slight shelf for the grease cup to sit on with the replacement. The bearing and shaft areas can't be inspected on the old bellhousing because that portion was destroyed.
Any ideas?
Thanks
Any ideas?
Thanks
