Wrong Carb Gasket?
saltysenior
Rebuilt carb on Johnson 9.9-1988-md#J10ECCD- Serial# E6284213-still having problems with keeping motor running. Looked up carb on BPR Parts website. It shows the carb I have --the cover gasket ref. #17, part # 0331750 or 0334043 shown in the blow up is not looking like any I got with my rebuild kit [part # 439073]. Could I have put in the wrong gasket? Two or three types came with the kit but none look like the one blown up.:confused::confused:
iwombat
Re: Wrong Carb Gasket?
Those lid gaskets have changed around some since the originals. Pick the one that's closest out of the kit, and it should work fine. What exactly is the problem you're encountering after the rebuild?
saltysenior
this rebuild job..[#3]....... i got it to run better......still have to play with the choke to keep it going......feel like i'm getting somewhere now...any ideas??::):confused:
iwombat
Did you remove the core plug and soak the carb body during the rebuild? If the choke fixes it, it's in the carb still.
saltysenior
did not soak& did not remove core plug.....what part is that on the blow up???........cover had cracked so i epoxyed it....replaced needle valve retainer,and now needle SEEMS to screw in farther before bottoming.....will experiment with that now....
iwombat
Sorry, forgot which carb you have. The plastic lid type doesn't have core plugs. My guess is that the lid is probably leaking air. You can get a new lid from the dealer (or maybe ishopmarine). I think it's been superseded by another part that's less likely to warp and crack.
saltysenior
played with needle valve and got her to stay running....'sea' trial her next....also found and epoxyed a small crack in the nozzel well...need to find some where to buy parts.....what i have to replace only comes in kits dealer says....3 kits i need cost more than carb....any body know of a place for used carb parts......jon.9.9 1988 j10eccd....thanks:redface:
iwombat
Might try looking on ebay for an entire used carb. Should be able to find one for under $50.
saltysenior
sure would like to find one.....also seem to have ongoing problem with small black particles in fuel system ....i placed a small in line filter 3'' from the carb,and i still find them in the carb..???
saltysenior
put the boat in the water....hard to start & hard to keep running.......after many choice words and kicks it started to run & idle ok.....still not 100%...runs fine and has ok power at wot....took comp test last week...gauge showed 60 psi in both cylinders...is that normal???
iwombat
Not great, but for a rope-start 9.9 it's not bad either. They're even and that's what matters. I still think your idle problem is that cracked and repaired plastic top plate. That contains all the idle circuits.
saltysenior
i just hate to pay $53 for a piece of plastic......i have elec. start...i keep the rope starter off because i remove the carb every day:D:D:D....worked fine at the house just now....:confused::confused::confused:
