Wtf
maharg
So I have now received my second ordered prop and it does not fit, it is same pitch, however it hits the anode. I had a half inch gap with the old prop, What an I supposed to do now, there is only one prop smaller in diameter than the solas one I bought, I already returned one and had to wait a month for the $ to get refunded. I want to take my boat out, but my first prop is bent and getting repaired. can I run it without the thrust washer? Or do I have to buy an anode? HELP!!!!!!!!
Its an 87 alpha 1 no power steering (teleflex)
The prop I bought is a 14 4/5 x17
If I need a trim tab anode, which one do I need and how do I install it?(hopefully I dont need one)
Should I send back the solas and get a Hustler?
Re: Wtf
Ayuh,... That propshaft looks awfully dry, 'n rusty.... Where's yer Grease,..??
maharg
Re: Wtf
Ill be adding grase, is it ok to grind it? Will it cause any change in performance or handling?
Bob_VT
Re: Wtf
Grinding a small notch will not hurt anything at all.
If you experience any change in performance it is due to a different prop design. That prop just has slightly more rake then the old one.
oldjeep
Re: Wtf
The hustler would hit too. You can either grind it or buy a performance trim tab or an offset trim tab.
maharg
Re: Wtf
I thought the rake was the pitch?
oldjeep
Re: Wtf
Performance trim tab is smaller (so it doesn't work as well). An offset just moves the whole fin back about 1/2".
Performance:
Offset:
