X66 idle speed has decreased
crazy charlie
2000 200hp Saltwaterseries 2 stroke sx200 . It appears that the idle speed has lowered a bit on its own. PM work that I have done in the past few years. New diaphragm style fuel pumps. Cleaned vst filter (looked perfect but cleaned it anyway) ,new fuel water sep every season. Tstats, New plugs every other season. Small filter near block looks fine but is due for a change. Runs and operates fine pretty much same for the 5 years I have it. The only observance I have made is that right at throttle up there is a tiny bit of hesitation, very slight at throttles up .The motor has always dont this but it is hardly noticable. dont understand why idle has slightly decreased????
dingbat
Components wear wear over time.
When was the last time you did a “link and sync” and adjusted the throttle cable?
99yam40
would not hurt to use a timing light to make sure the idle timing is still in spec and advancing properly
