tkrfxr
Thread starter- Joined
- Nov 10, 2009
- 313
At my last outing, I saw a small amount of oil shining behind my boat...Blamed in on the guy next door...but the port Volvo XDP-B (1.96) drive had lost about 4 oz. of gear oil from the engine reservoir. At haul-out, the drive had gear oil coming out of one of the small drain holes, and the stbd drive was intact. When the cover was removed, there was oily film all over the inside of the cover, the hose, the shift lever...I suspect there is a leak through the shift lever. (The universal joint bellows was dry inside, and the propeller shafts were dry...)
I drained the gear oil on both drives. The stbd drive oil is darker than port's (olive oil and extra virgin olive oil). There is no water...the gear oil is full synthetic, and there is no "fur" upon removal of the drain plugs.
I'm headed down the path of a pressure test...but can't find the XDP shop manual, even on the iboats VP Store (Part#7747145 or 7747250). How much pressure should I use, and should I do a vaccum test? It would be hard to see where the leak is by vaccuum testing...I think..
