xr-2 150 hp timing
wrenchtrnr72
can someone please tell me the procedure and specs for setting the timing on an 1981 merc xr2 150. i still have no go prob when in water. replaced stater w/high perf. stater replaced switch boxes with high perf. boxes, rebuilt carbs, compression is 130 lbs on all cylinders. motor runs great on land. but in water will not go on plane just boggs
achris
More fish than mountain goat
Re: xr-2 150 hp timing
Hello wrenchtrnr72,<br /><br />If you're going to tackle a job like this, then do yourself a very big favour and buy the service manual. They don't cost a lot and the information you get is priceless. You'll need to give us the serial number of your engine as the XR-2 was only produced in 1985, 1986, 1987.<br /><br />Chris..........
Hooty
I doubt timing iz your problem. Have you tried bumping the primer switch when engine "boggs"?<br /><br />c/6<br />Hooty
wrenchtrnr72
my serial # is 5503559. i did try pumping primer ball annd even pushing cold start injector, that made it bog even worse?
achris
Wrenchtrnr,<br /><br />Your motor is 1980. It does sound like a carb/timing sync problem. Give me your e-mail address and I'll send you the 3 pages from the manual.<br /><br />Chris..........
wrenchtrnr72
my e-mail is wrenchtrnr72@msn.com. info would be helpful for me to keep on file. mu friend use to race mercs, he had me back in water with boat on trailer tied down, and checked everything under a load. he played with timing and trigger and other things, stuff i need to learn! wook boat to lake today(7/5/04) and i 'bout made a mess in my droors!!! boat ran 75 mph!!!!! i am the happiest man in the world now!
achris
One happy chappy!<br /><br />Sent you the pages.......
wrenchtrnr72
thank you very much, these are going in my boat book, i really appreciate it. i need to learn this stuff.
