xr2 cowling on my xr4?
mogfisher
I've been looking to pick up a new cowling for my xr4 since mine is pretty beat. If it just had scratches or whatever then I'd paint it, but it's cracked and chunks are missing. Looks like a beaver ate it! Anyway, I've found a couple cowlings. Cheapest is an xr2 cowling but there is also a blue band 200 blackmax cowling too. Would either of them fit? They LOOK like the same style, but I figured there might be some differences. I know the xr2 is a totally different motor than the xr4 too. Thanks folks!
Adam
j_martin
Re: xr2 cowling on my xr4?
Adam
Early XR4's had a 16 amp electrical system and a clamshell cowling. Later they went to the wet 40 and a bucket. The clamshell won't fit over the 40 amp flywheel cover.
If yer 16 amp, I don't see why it wouldn't fit.
What is it with XR4 cowlings. Mine's pretty ratty, also.
John
Dukedog
Mine are still pretty nice :p
mogfisher
mine is a clamshell style. Its an 89. So does that mean that an xr2 clamshell would fit on there? I'd re do the decals but will it fit? The xr2 cowling I'm seeing looks pretty nice actually so I hope it will fit.
Dukedog
Any XR2/XR4 clam shell should interchange so it should work just fine...
All clam shells are tha same as far as size. Tha only difference will be in tha front of tha cowls and how they latch. Vertical reed motors have tha metal "spring" type latches. Horizontal reed motors like tha 200 are cut a little different in tha front and use a single "wide" plastic latch. Tha XR2/XR4 can be modified to fit any 2.0/2.4 horizontal reed motor as is mine.....
Even got a friend thats fabing up some brackets so I can put tha XR4 clam shell cowls on one of my 2.5 motors............
sschefer
Adam
You can run any bucket style upper and lower cowling set up to 1999 but not the DFI versions. They sit further back and will cause a problem at the carbs.
You need to have the correct mounting brackets on your mid. If you have a clamshell style vs. the bucket style as in the pictures i've posted you will need to change the mounting brackets. I'm going from memory but I don't think you need to pull the powerhead to change them but I could be wrong. I'll look later today, I have a mid sitting in the shop.
These are 96 EFI's on a 89-90 135.
These are 99's off a Carb'd 200 motor -
Dukedog
You can have one just like it for a "small" price :D
A tad bit cheaper than "Titus" but not by much.............
mogfisher
That looks really nice! I will definetly go that route once I do 10 million other things on this boat first! For now I think I'll just stick with the clam shell style. Today is my lucky day too I guess. I found a 200 clamshell for 80 bucks about an hour from me. To boot, he is drivng right by me tonight at 7 and I'm meeting him 5 minutes from my house. Doesn't get any more convienient than that. Thanks for all the info. I will definetly do the bucket conversion at some point, but for now I just need something better than the cracked up POS that I have.
sschefer
Ahh yes... well once I get a new hull and break away from the these 25's I'll be ringin you up. The 200 hot rod will be the motor not sure about a hull yet. Thinkin Ali 2002/2003 Might just have to make a trip to Tennesee next winter.
Faztbullet
The 18ft Bullet I traded for is for sale cheeeeeeeap! Needs some TLC on deck and carpet but solid boat. Duke is that a Lazer or Stream? The gunnels throw me!!!
Dukedog
Laser......
Send me more stuff 'bout tha Bullet. I'm always lookin' for something ta play with..........
