BassHole559
- Joined
- Aug 28, 2018
- 17
I’m having the common momentary hesitation on rapid throttle advance but smooths out. Sometimes if I let it sit in idle for about a minute then gun it, it Boggs down and dies. Motor isles fine. It’s a 2002 XR6 150 S/N 0T591137 I timed the motor using the upper starboard spark wire as that’s what my manual calls my “no.1” cylinder to specs. Did the link, sync, still momentary hesitation. I’ve changed, bulb, all fuel hoses, fuel pump, both fuel filters, verified Thermal relief valve operates, checked all bleed check valves and replaced all hoses, inspected reeds, replaced all gaskets, thoroughly cleaned carbs, adjusted floats, etc. compression was solid at 115-118 psi. I Tested my entire ignition and charge system. Replaced my entire cooling system. Everything is good. I even took my seats out to look at my fuel tank and see if it was venting properly. After all this I did timing and sync once more to make sure. So I’m confident it’s all down to fuel air mixture. Fresh 87 octane non ethanol with stabilizer was used.
I got the manual for the WM carbs and I’m confused about a couple things. On their diagram, it says the TOP PORT barrel is the No.1 cylinder on one of their diagrams. PIC is below post. Before someone says I’m looking at it wrong, the sync link lever is key. I thought for sure I was looking at it wrong until I saw that. Not a big deal if the jets were all the same size, but that’s not the case. So, is it possible the different size jets are on the wrong side of the carbs and that’s causing my Issues?
Second question, idle air mix screws, manuals say these things should be adjusted evenly 1 1/2 +\- 1/8 turn. There is no way to hook up a vacuum gage to tune these guys and adjusting them Evenly makes no sense if a couple of the jets are different sizes. Right now all my needles are turned out 1 5/8 turn. Less than that the problem gets worse. More, than that worse.
im stumped but determined to get this problem fixed. Please advise. Thank you in advance.
