merc150
- Joined
- Jun 17, 2013
- 110
Hope you guys can help me figure this out! I have a 2003 merc 150 xr6 CARB motor. I changed the thermostats,poppet valve,temp sensor for the gauge, new water pressure and temp gauges,spark plugs (yes they are the correct ones) and did a complete water pump kit, all parts are from mercury, (also back flushed the cooling system with a water hose and found nothing),inside of the heads look clean. I also rinse the motor with salt-away everytime and after every use. I had the cooling issue before I did all this work also my compression is 125 in a 6 cylinders. The motor seems to run hotter at lower speeds but will slowly cool to 190 or so at WOT. At slow speeds the motor will get close to 200 degrees before I turn it off (seems like it will just keep getting hotter). My water pressure is good (3-5 at idle and 11-13 WOT). I also went from a 19p prop to a 15p prop and that didnt help any (Stiletto props). I looked at the water holes in the lower unit and they are clean. The motor is mounted at the correct hight on the transom. Im in florida and right now the water temps are 90 degrees.I was thinking maybe the timing is off but looking at the timing screw it doesnt look like anybody has messed with it (factory paint is still alined on the screw). The motor runs absolutely perfect except for this cooling issue. I also used a laser temp gauge just to make sure my gauge was right and it is. ANY help would greatly be appreciated!!! I need to get this fixed ASAP I have tournaments coming up. THANKS
