FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Hello guys 1987 searay, engine is out and find out im missing one of the engine flappers, i guess is down the pipe, so im trying to remove the y pipe has two bolts but they look like 12 points head bolts, what kind of tool should i need to use.
Have you checked the drive for the missing flapper? That is where they usually end up. It might save you some work if you find it there. But like the above posts stated it is a 12 point. Get a good tool set and they will be included.
I don't see you being able to remove the Y pipe without removing the engine. If the drive is removed you might be able to see the piece and grab it with something like this
It's called a 12 point socket, it's 3/8", and there are 4 screws. 2 on top, and 2 below. The broken off pieces may have been flushed through. Have a look at my sticky on exhaust shutters. HERE.
Hi guys the engine is out, the drive was removed before when I change my bellows, bearing and the shutter wasn't there, and i guess something happen with the bolts because is only two there.
If you only have two - which two are they? The top ones? It is not unusual for the bottom part of the Y pipe to be corroded. Hopefully everything will be fine on yours. But be sure to evaluate everything when you put it back together.
Just a quick side note - it is possible one of the top bolts is not being used. There are two configurations of the bolt patterns. One is for the Y pipe used on V engines, the other is for the single pipe. Hard to believe, but Mercruiser is okay with just using three bolts if they do not all line up. I used to have a Sportcraft with a 305 Chevy and Alpha outdrive. When I pulled the engine and Y pipe I discovered the holes did not match up. It came this way from the factory. Long story short, I contacted Mercruiser and they said it was an accepted practice to use just the three bolts. Here's a pic:
