I have a 1999 Mercruiser 350 with a Bravo III drive. I pulled the motor to repair an oil leak but have a question about the Y pipe to Gimbal Housing seal.
My Mercruiser Service Manual indicates that only an o-ring is required between the Y pipe and housing.
When I took the Y pipe off there is a ton of sealant around the o-ring. Is this something extra the boat manufacturer did to help ensure a good seal or is this recommended? What if any sealant should I use?
Attached is a pic of the gimbal housing showing the white colored sealant.
