yama 85c tlrs still have water in cylinder
jimbobo
i have a 1994 yamaha c-85 tlrs. had water in #3 (bottom cylinder) was advised to remove cylinder head and go from there. replaced head gasket.cylinders looked fine. put a straight edge on head and appeared to be straight. put the ear muffs on it fire it up and #3 is still getting water on spark plug. cylinder is not firing. i can pull plug wire off while running and it does not make a difference. i have spark. is it possible to be leaking water in through the exhaust somehow? i have the clymers manual but it does not help me troubleshoot this problem. any help or advice would be appreciated. thanks -jim
