yamaha 115 carb. float height
cuenta
When I bought this motor had overheating at high revs.
I changed the water pump, thermostats, popet valve and cleaned the water jacket but the problem continued afterwards, remove the carburetors and found the floats, each one with a different measure, I adjusted them to 16mm and the overheating problem disappeared but now when I accelerate from idle to 1/2 throttle has a rough and then in WOT it stabilizes
I assume I have a rich condition .
my question is if i buy the new floats are they already adjusted to the correct height ?
