mevans27205
- Joined
- Feb 8, 2010
- 11
Motor is a 97 115, 6E5 115TJRV 2 stroke
I just recently switched Outboards from a 90 to 115Jet, non oil injec to oilinjection. The 115 ran great smoth idle no stumble between low and High speed, I ran the 115 for over an hour before buying and making the switch.
Afterwards on My boat it will not plane out and only seems to run at about half throutle or power. Im wondering if some of the wiring is diff from a 703 control to 704. I have two plugs not used with My cotrols, one plug on the motor has two wires green/red and green/black which come from the oil tank under the hood and one other pig tail that has a black orane and pink wire that looks like it goes to the tilt trim. Is one of these causing a safemode condition and can I bypass it? I have a 115 manual on order just not in Yet, thanks for the help. Oh yeah I need to add no alarm at all and it does seem to be using oil, I topped off the tank and it was down after running.
Thanks, Mike
Thanks, Mike
