edgutgesell
- Joined
- Jul 18, 2004
- 144
I have a 1985 150 Yamaha V6 (150 ETLK). It has been running lousy since going to ethanol fuel. I decided to pull the carbs to clean them. As suspected, there was alot of crud in the float chambers. I soaked the three carbs overnite and then blew out the circuits with compressed air. Reinstalled the carbs and the engine seems to be running much better.<br /><br />My question is:<br /><br />I have two manuals for my engine. One is the Yamaha factory manual and the other is a Sealoc manual. For the initial setting of the air adjusting screws in the Yamaha manual for my model carb (Takei), the adjustment is 1 1/4 turns out from fully seated. The Sealoc manual says that the air adjusting screws should be 1 1/2 turns out from fully seated. One of the manuals and I am not sure which, said that these air adjusting screws are not to be adjusted and the 1 1/4 or 1 1/2 turns out are the final setting, no tweaking. I set my carbs to 1 1/2 turns out from seated because I didn't want to set the carbs to run too lean. Even though my engine seems to be running better, it seems to be burning more fuel than before the carb cleaning. Can you tweak the air adjustment? Is the turns out from fully seated the absolute setting?? Turning the screws in leans the mixture, right? I would like to believe the factory manual however I have found some mistakes in several areas of the factory manual. In some cases the same mistakes appear in the Sealoc manual. Who do I believe for these carb air adjusting screw settings? I have a tendency to believe Ray N. or Rodbolt before believing these manuals!!!
