PatrickGold
- Joined
- Sep 28, 2007
- 20
I have a 1995 yamaha 150 with oil injection. The problem I have is that the oil pump will not run to pump oil from the boat's reservoir to the tank mounted to the powerhead.
1.) The manual override switch works and the tank fills.
2.) When I first turn the key the pump turns on for 3 seconds
3.) When the engine is tilted up, the oil pump will not run when the key switch is first turned.
I have no clue what to try next and I appreciate all suggestions.
