yamaha 1999 200 ox66
geckoman7783
bought rebuilt powerhead transfered everything from one motor to other plug everything in the engine backfires through the exhaust checked key and is good what can be the problem any info be appreciated
WillyBWright
Re: yamaha 1999 200 ox66
It's either a timing issue, or a firing order issue. Did you determine what ruined the previous powerhead?
Ray Neudecker
What happened to the previous power head? Have you done anything to cure previous problem. If not expect the same results again.
geckoman7783
well the first powerhead had a bad bearing noise in it and viberated real bad ran excellent on top end i changed powerhead plugged everything as needed when trying to start backfires through the exhaust a real loud one too.getting spark anf fuel
Thanks Ken Steele
Ray Neudecker
Have you checked or had checked the fuel pressure and injectors? Are your pumps fresh? Cleaned and tested the 02 sensor?
geckoman7783
well had fuel system check out seemed to be in good working order i have not checked the o2sensor but i will do the following what else do i look for
geckoman7783
well the injection system tested good and o2sensor good also put a timing light on it today and is out 10 degrees before tdc
