Yamaha 1999 250 OX66 running hot
jfbetz
I have a pair fo these motors on my rig. A couple months back, both were rinning hot only at low (below 1500) RPM's. Changed out Poppit Valves and 1 engine corrected. Of the remaining possibilities (water pump or T-stats) which is more likley to be the culprit, or is there something else to consider. When above 1500 RPM, the engine runs normal temp. per the temp. gauge.
matt2002
Re: Yamaha 1999 250 OX66 running hot
When was the last time you changed the impellers ? Maybe they have a "set".
jfbetz
Impellers were changed out in May of last year. I usually get a solid 2 years out of them, and even then when I change them out, they are not terribly set.
