Outboard Mike
Thread starter- Joined
- Apr 26, 2009
- 55
Have a 2006 Yamaha T50TLR 4 stroke with EFI that will run for up to 40 minutes and then stall out and not start. If you let the engine sit for a while it will start back up after it cools down. We have replaced the low pressure fuel pump and replaced the fuel lines but still have the same results. The next step is to replace the high pressure fuel pump. I know there was a fuel restriction issue with some Honda 50hp 4 strokes that involved a grommet on the high pressure fuel pump expanding or bloating after running for 20 minutes or so and blocking off the flow of fuel to the engine and causing a stall condition. The configuration is almost the same on these motors as the Honda but the part is called a pump damper on the Yamaha. Has this been identified as an issue on Yamaha 4 stroke EFI models. I hate to spend over $300 on a high pressure fuel pump if the damper or grommet is the issue. Best time of the year to be on the water and hoping to get boat running right.. . .
