FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Might be wrong, but I’m not sure a faulty rectifier would produce more volts as a failing. Sorry to ask, but have you verified this using a meter on the actual battery ? Or are you going by the readout on the dash ?
HAD A VOLT METER ON BATTERYS PLUS MY CHART PLOTTER SHOWS VOLTAGE dash meter starts flashing after it gets to 15.5 like it telling me something is wrong. at idle is 13.5 at 3500 16.2 Had a used motor put on a few days ago and that's when it started trying to get my rectifier off old motor had no problem with that one?Thanks
Ah. Fair play. Sounds like it’s a genuine over voltage then. Got you. So you must have a combined regulator/rectifier type on your engine. Sounds like you know what you have to do then.
I would take apart and clean all the connections from the battery to the motor. A loose or faulty connection in the system can cause high voltage. I had the same problem last year and found the negative post connection was loose. A 15 minute job and no dollars spent.
