I have a 200 yamaha, I believe it is a 90 model. The trim/tilt has given me problems in the past, but has just required topping off the fluid. Now one of the lower pistons operates, but the main and other side piston do not. I have topped off the fluid, to the best of my ability considering the precarious position of the tiny fill hole! When I take the piston out of the cylinder, there is air behind it which seeps out as i unscrew it. The fluid is also milky denoting air in the system. The pump and electrical portion work fine. What should I do to get this thing working properly? Any suggestions would be much appreciated as my frustration level is increasing.
