ShinobiTTZ06
Thread starter- Joined
- Sep 19, 2016
- 7
One of my motors ('86 V6 special) is leaking 2 stroke oil out of the exhaust prop area down the skeg. If the motor is tilted up there is 2 stroke oil coming out of the breather covers/plenum of the lower carbs and there is residue on the bottom of the engine bay. I cleaned all that up and placed the motor in the down position. When I cycle the key on, I get the low oil warning alarm as the remote tank on the motor drained all the way down, it used to hold oil in it all the time. I run twins and the other motor is fine.
I allowed the oil remote tank to fill up, and the oil warning went away. After a few hours I noticed new 2 stroke oil coming from the bottom of the skeg onto the ground, I noticed the remote tank level was no longer full, bled down. I inspected the engine area and didn't obseve any oil in the upper cowl area or around any of the oil line. I cleaned up the ground, came back in a few hours and the oil was on the ground again, and the remote tank was at 1/2 way mark, again, again, until the remote tank is empty and all the new 2 stroke oil is all on the ground.
Clearly the 2 stroke oil is leaking and bleeding down past something in the oil injection pump. There is no oil leaking from the top remote tank cap, oil pump, or lines themselves, as I cleaned the entire inside bottom of the engine bay and it is still clean, nothing on the bottom of the cowl. The 2 stroke oil is going through the oil injection pump or possibly one of the lines and coming out of the exhaust port area and down the skeg onto the ground.
I noticed on the motor that is not leaking that the Keihin oil injection pump was replaced with a Mikuni. The part number for the conversion kit appears to be unavailable. Are the oil injection pumps rebuildable, or does anybody know of a conversion kit that is available? Or could the problem be something else I am missing?
Thanks
Thanks
