yamaha 3.0 l4 blew head gasket help!
Flashcardsgo
If the engine was over cooling you may get milk in the rocker covers simply because the oil doesnt get hot enough to boil out any moisture out and it condenses under the covers and thus the milk . Is your t/stat working ?
I’m not sure. The temp gauge on the dash Never gets hot stays pretty steady. Good oil pressure too. Just want to get rid of that milky in the oil and somehow add something to clean up pan . Then put fresh oil , filter and put her back together. May switch out head , lifters. Pushrods over the winter.
Flashcardsgo
Re check your compression numbers, new engines are only 150 psi, might be a bad gage.
It is a brand new gauge and I did it twice , my boat mechanic ( now retired) said that 180 was great so idk. I adjusted the valves got quieter and ran good but now I need to get that milk cleaned out of oil and engine somehow before I change the oil. I can’t even figure out how to change the oil because I can’t get to the pan bolt good enough to break it loose and I’ve tried to extract through dipstick but my brake bleeder pneumatic tool wouldn’t work nor a hand pump because hose too big to go in dipstick.
Grub54891
I adapt the hose for my vacuum bleeder to fit the outside of the tube, mine fits tight to the tube so I don’t need to clamp it. The tube goes to the bottom of the pan on a mercruiser, I’m not sure on a yamaha but I would think it would. Warm oil works best for extraction.
kd4pbs
Polyethylene tube snaked inside the dipstick to the bottom of the oil pan. Suck it with whatever you have that sucks (besides the Yamaha outdrive ;) )
Flashcardsgo
Ok I adjusted my valves which was a mess with the milk on them splattered everywhere 😩. The engine did smooth out and get quieter. Here’s the deal now I need to change my oil and I can not get to the dipstick block bolt and I can’t get my pneumatic brake bleeder to suck up the oil from the dipstick. I tried a hand pump no good either . I need to get that bad oil out and then somehow put something in the block to blend it out better. Any suggestions ? Who is it so difficult to change the flipping oil ! Sometimes I here this boat but my grandkids love it it seats 14 and I’ve put new gauges , floors , carpets , seats , stereo , Bimini etc in it so I’m not getting rid of it. Thanks. I’m covered in milk splatter and not happy right now ! You can’t put a drain pan under the motor either. They should have had a better system to change oil without pulling the dang thing. But it is a Yamaha smh
Got the plug out not much oil came out but it was milky. Going to pour quart of motor flush in it and see if that will get it cleaner. I will then change the oil and filter and try to run it and see how she does.
matt167
I use a $5 transfer pump that you can get at any auto parts store, Walmart or HF. The prices run $5-15 or so depending on where. Hook the small line to it and snake it down the dipstick. It’s a slow process. The pump draws a vacuum and you’ll hear and feel it working
Flashcardsgo
I’m going to replace the thermostat before I put it back together. Not sure which one to get since there’s virtually no way to source
New parts
Flashcardsgo
I did buy a battery powered transfer pump from Harbor Freight but the hose size wouldn’t go down into the dipstick. Tried several ways to get it through there but ended up able to get the plug out of dipstick block. Only problem is it’s very hard to get back in doesn’t seem like it’s catching the threads or tightening up and the block seems to be pushing back against me when I’m trying to reinstall it.
Mc Tool
New parts
Its probly got the temp stamped on it somewhere and as long as you get one the same shape , auto parts store :)
Flashcardsgo
I really appreciate all you guys support being an owner of not one but 2 30-50 year old boats is sometimes a challenge and frustrating. Especially the Yamaha , when I had a chance to purchase a low hours clean head , manifold and lower unit drive for 900.00 I couldn’t pass it up because of the rarity even if just to hold until needed . With the valves adjusted and now able to change oil looking for suggestions on how to proceed from here . Should I just fill it up with oil hook the muffs up and run till warm and then extract what’s in there or try some sort of flushing measure. Then put fresh oil in it new filter & valve cover gasket and just use it like normal on the water. My only concern is although I drained it & cleaned head , valve train etc after putting a quart of motor flush in and on top of head is running it with water in it is going to froth up more milky and I’ll have a mess all over again.
kd4pbs
I hate to be the bearer of bad news, but if the oil you drained was milky, the oil you replaced will also become milky. You've got more issues than a thermostat which is not working properly.
Cracked, head, blown head gasket, freeze damaged block... something is allowing water to enter your crankcase. For sure, condensation will not cause the oil to get milky like that. Even without a thermostat, and even if you were running in 33° F water, the head, coolant, and oil temperature would be well above the dew point after warming up, and any small amount of condensation which may have appeared would be boiled off.
Grub54891
I get the condensation up top at times. Good hard run takes care of it. On others I’ve worked on that got submerged we remove the oil, re-fill with cheap oil and a bit of sea foam. Run it a bit and drain/flush a few times with the seafoam. When it comes out clean we put the good oil in and take it for a good run.
Flashcardsgo
Update. I had a blown head gasket & a bad spot inside the manifold at the center port. Someone previously had tried to weld the broken center port devider and that the area I had a previous exhaust leak also. I have replaced the head with a fully serviced ( all new seals , rockers etc. ) and I found a new manifold also , finally found almost every gasket I need , still trying to source the tiny thermostat but getting there . Putting new boots on the riser & exhaust also. I have pics of everything but this forum won’t let me post any ! I have drained the oil and flushed with Deisel fuel and then with motor flush and I am also going to fill with boxed oil and run while I adjust valves then drain that oil and filter and fill up with good oil ( providing the milk is all gone ) and new filter. Hopefully everything will be much better than before and definitely quieter I’m sure. Thanks for you guys help and wish me luck ! Does anyone know where I can source that thermostat and do you guys think I should replace the water pump in the outdrive ? Thanks again. Tom
kd4pbs
Glad to read it's on the road to recovery. I wouldn't replace the circulating pump unless I had cause to suspect it was leaking or the impeller had eroded from running in salt water for decades.
Flashcardsgo
The only thing stamped on the thermostat is patent number. It’s a tiny little thing and googling it doesn’t seem to bring up anything even eBay. I wish I could send pics on this site . Wow they fixed it. 😁
Flashcardsgo
Never been in salt water but my previous boat mechanic ( retired this year ) said to replace the rubber impeller every couple years. I’d rather not take the lower unit off it’s so hard to find parts but I don’t want an issue with it when I’m done. I just need to find this little thermostat somewhere
Flashcardsgo
kd4pbs
Sorry - I was reading that on a little screen without my reading spectacles and thought you were referring to the engine circulating pump.
If the age of the impeller is unknown, replacement is wise.
As far as the thermostat goes, search for these:
Mercruiser 59078
Mercruiser 18-3650
Mercruiser 18-3550
