yamaha 300 hpdi runs rough
WRECK
Engine has 450 hrs, runs rough , compression 100, what can we check? Can ethanol damage these engines, Thanks
Paison
Re: yamaha 300 hpdi runs rough
Check plugs first. I have a Pair of 300's and go through quite a few plugs. Do you have a 10 micron water fuel separator installed. If not you would be saving yourself money in filter costs. Especially the metal $70.00 filter on top of the engine. Have you had the oil pump replaced ie. Yamaha recall? Check compression in # 2 cylinder. Or all of them while you have the plugs out. Try these things and maybe you can come up with an answer.
Regards. Charlie C.
yamamarinetech40
WRECK, when you say runs rough...idle, high speed, or always? Start suddenly? How much ethenol? You could get a glass or clear container and shoot a sample(pint at least) with the primer bulb into it...see what comes out(you know what FRESH gas smells like). Could be so many things, from so little info....
WRECK
I 'm trying to get some info; the boat is now on land, owners tell me it runs rough, as is sale. Open to all options? what should be compression 2004
motor, 250 -300 hpdi 2003 -2004 same? Thanks for the help.
rodbolt
compression should be within 10 PSI on all cylinders.
look at the oil pump control arm, it should be a 60VD4 I believe,
if not there is an update.
runs rough can be a host of thigs from cheap to very expensive.
