Yamaha 3cyl 60hp two stroke
Kymbo
My motor will indeed all day long but as soon as I give it throttle it runs fine for about a minute then bogs down an will only idle let idle for a bit an then takes off fine butt bogs again
Inspect change fuel filters.----Test run with another tank and hose.
99yam40
fuel pump or sucking air maybe
does it help to pump the primer bulb?
Grub54891
I'd do a compression test also. I know the evinrude/johnson motors would lose the center cyl often. I'm not sure about the yammies though if they had the same issue.
