micmor64
Thread starter- Joined
- Dec 9, 2015
- 46
A lot of searching and reading old posts and haven't found an answer that worked for me... So thought I'd post a new thread.
1999 - 9.9 high thrust 4 stroke - motor has 22 actual run time hours on it and it ran fine the last couple of years until an intake valve bent. Just finished a valve job and it starts and runs great at mid to high speed, but will not keep running under (i'm guessing) 1500ish rpm (no tach to measure actual). I have gone through the carb having just replaced the main needle, diaphragm and bowl gasket. cleaned the entire carb pulling both main and idle jets, removed the cover and cleaned the ports in the throat from the Air/fuel Mix screw.
I've spent hours trying air/fuel needle mix settings from 1/2 to 4-1/2 turns open in 1/4 turn increments. Every time i drop the throttle below 1500ish (guessing) the engine drops off and dies acting as if it's out of fuel. A couple pumps of the diaphragm and throttle reset to mid range and it comes right back and runs great but only at mid to high throttle settings. I'm and old JhonnyRude 2 stroke and am new to Yamaha 4 strokes. What am I missing to get this motor to idle?
