Yamaha 9.9 High Thrust 4 Stroke Electric Start
gump218
My 9.9 routinely has starting problems due to what I think is low voltage. Once I clean electrical connections, she kicks over fine.... Does a 9.9 4 stroke electric start provide any charging to the battery when running?<br /><br />Also, I get a good idle and seem to get good high speed but there is a point where the engine tries to stall out during acceleration. If I milk the throttle, I can get thru that zone to high speeed. Ideas?
gump218
Re: Yamaha 9.9 High Thrust 4 Stroke Electric Start
This is a 1995 T.9.9EXHT 6G8UL 787273
ST
The 1986 9.9 Yamaha service manual shows it has a "CDI magneto" charging system made by HITACHI. It says: "Lighting voltage: 10V or more at 3000rpm; 15+/- 1.5V at 5,500 rpm". <br /><br />If I am not mistaken; my motor develops a reading of 14V or so when I ramped up the rpm higher than idling.
gump218
Guess I can throw a meter onboard and take a reading while motoring... I'll check it out..
josef camilleri
Guys I am new here ,i am changing my engine for a 4 stroke yamaha or suzuki can anyone help please 150hp
gss036
josef camilleri josef camilleri is offline
You need to start a new thread/post and give more details on your boat and current engine.
Casco Bay Outrage
Gump -
Clean the carb for the stumbling. It is telling you there is gunk/trash. It will only get worse.
