yamaha 90
illman
wont go in reverse just grinds,was going in reverse every now and then,also neutral hard to find,should i start with cable?
noelm
Re: yamaha 90
need to do some very simple tests first, put the lever in neutral, take of the motor cowling and have a look at the adjustments, remove the cable from the lever at the motor end, slowly turn the prop (with your foot, or a helper) and see if the selector moves into reverse ,neutral and forward easily and does it fully engage? from there you should be able to see if it is adjustmenst, cable or something broken.
illman
Re: yamaha 90
did what u said,turns out cable was not adjusted right on engine,adjusted cable longer by 1/8 in and now it works perfect,thanks for the help.
