Hi,
I have a 2005 Yamaha 4HP (4-cycle) outboard (F4A) motor. That I recently reclaimed and proved to be alive and kicking.
I ran this motor yesterday evening in a barrel with a good water level and the tell-tale was producing a good stream of water coming out.
Anyway, after some time playing with the motor at idle speed I did 2 or 3 WOTs for about 2-3 second time intervals. Then I slowed it down all the way to IDLE speed (in gear) and noticed that the motor started to die and finally after 4-5 bursts of brummm - brummm it finally died. Right away I shifted to Neutral with throttle at "START" pull it and it fired right up without any issues. I repeated the scenario, 2-3 short WOTs and lowest RPM while in gear -- and she does it again - broommmm..brummm and died.
Then I did the same thing but once I reached the lowest RPM switched to Neutral but still the issue was still there and she died again!!!
Then I really wanted to see what was going on internally and while it was "wrooommm ..wroooING" I unclipped both cowling latches and ...... once I lightly raised the upper cowling off the motor she fired right back to good Idle RPMs!!!!
I repeated this procedure several times and it was consistent - she revives as soon as the cowling is off!
Now, all the tubing/ hoses and wiring is nice and per original placement within the motor's enclosure, the cowling itself is plastic - nothing should be shorting, I think (strongly believe) that none of the air / fuel hoses get jammed while the cowling is on. What am I dealing here with?????? The only conclusion I could come up with is that the air gets too hot inside the enclosed space of the motor thus making the AIR to FUEL ratio very in-proportional.
Please help me out with my motor's mysterious behavior?
Thank you in advance,
Kuy.
Kuy.
