Yamaha F150 2008 wiring/connections questions
FrenchFry
Opening a new post since maybe nobody saw this.
Little help needed for the wiring/connections, I don't know exactly how to connect everything in first picture.
I did not have the water/fuel filter, so I have it now, this is the blue connector, OK
The square connector in my hand with the red cable is to connect a second battery, OK.
What is the triangle connector?
And what are the white and (apparently not used) other connector with rose cables that I have put near the oil filler for the picture?
See on the second picture the cable that goes to the throttle, I have the white adapter that apparently fits nowhere.
FrenchFry
OK, solved, the triangle connector is the trim (so useless when using the main harness), the white connector with white and blue wires is the one to connect to the cable, I have the wrong adaptor for this, and I don't know about the last one but it is not used.
FrenchFry
The adaptor was correct but one cable missing, interesting Yam document here:
