YAMAHA F225 SURGING. rodbolt question
I have twin 2003 F225s. the starboard motor will intermittently surge only when the RPM range is between 8-1200 usually after coming off plane. I can increase idle and the surge will go away. does not happen on a regular basis, maybe once every few trips, but has been doing it for about a year now. Motors have 500 hours on them.
All filters and plugs have been changed, pumping bulb does not fix issue, TPS has been tested and set. no codes.
ANY THOUGHTS?
THANKS
99yam40
Rod does not post here anymore, but maybe someone else can help
You can do a web search for Rodbolt17, and I am sure you will find the place he is active
99yam40
Rod did finally give an answer to your post ,
so just making sure you realize that he did and go have a look
