littlefeet
Thread starter- Joined
- May 26, 2007
- 1
Hi all,
Last week I installed new plugs in my Yamaha 115 salt water special year 1998. I put it in the water it ran well for about 20 min. went back to dock. Next run started out ok, after 5 mins. motor stopped. Limped back to dock. Here are the symptoms: runs well at above 14oo rpm. will not idle, choke helps some. Hooked to alternate fuel system, no help. While running engin above 1400 pulled each plug wire off one at a time, first 3 made no change in engine. when I pulled the last off motor died. (replaced each b-4 removing next) Checked compression each cyl 125 to 135 psi. Any ideas?
Thanks for any help. Bob
