yamaha l4 3.0 flywheel
bad2dabon
I have a 92 yamaha l4 3.0. I am starting to have trouble getting speed out of it. The motor rpm's is running about 3500. Engine checks out good. I hear a metallic sound coming from the flywheel area. Is it possible there is a problem with the flywheel that would be causing me to loose speed?
ricovw
Re: yamaha l4 3.0 flywheel
I doubt the flywheel is causing you to lose speed. There are a bunch of things that could cause it. Have you checked your timing lately? You need to use a jumper wire on the distributor to time it correctly.
