yamaha l4 3.0 stern drive
bad2dabon
I have a yamaha stern drive that is shifting hard into neut and reverse. this is my first boat. I thought it was a shift cable so i pulled the outdrive off and realized that cable was working smoothly. The shifting fork is stiff. but when i removed the 6 bolts from the lower housing i can not get it apart. any suggestions?
QC
Re: yamaha l4 3.0 stern drive
I moved this over to the I/O section. Thinking more action here for you. Welcome board!!
Capt Ken
Are we having fun yet? Well you forgot a bolt. There is 7 bolts. #7 is in hole above the prop. After you get it apart, gently remove the bronze fork and don't go hitting it with anything. It bends easy. After removal, clean out the bushing that the fork pivots in.
bad2dabon
Well thanks Capt Ken will give that a try this weekend and post results
bad2dabon
Capt Ken amazing how easy things come apart when u get all the bolts out. Hey but have attached a couple pics of something i found that i am sure is not rite but need to know what it is so i can get another one when i go to pick up my seal kit. Can ya help? thanks
