yamaha multifunction temp guage issue
pro sport 22
I recently installed a new multi function yamaha guage in my boat. the temp guage flashes constantly.
i have checked the dip switches on the back and set them accordingling as per a previous response to another post.
any ideas?
rodbolt
Re: yamaha multifunction temp guage issue
post the engine model number and post where you have the three dip switches now.
pro sport 22
225 ox66. dip switches are on, off, off.
rodbolt
thats not a model number
the ox66 225 was made from 1997 to at least 05 in a VX,S,SX and an L version.
need a model number to identify which trim sender you have.
if you have a 3 wire then set the switchs to 0ff,off,off.
sometimes you have to flip them on then back off.
is this a new from a dealer tach or a new to you tach?
if the switch settings are correct unplug the gray wire at the 4 pin trim harness connector under the hood and see if it still flashes.
pro sport 22
thanks very much rodbolt. i will check this out this weekend and get back with you.:)
pro sport 22
the guage is brand new from the dealer. one other problem i did mention is that the trim guage also does not work.
pro sport 22
Change the dip switch postions to Off, Off, Off. No change.
The model # is SX225TX?
Have not had time to research the trip problem yet.
pro sport 22
Have unhooked the grey wire.
Have reset the dip switches to off off off
The model is SX
No change.....
rodbolt
still need a FULL model number AND the tach part number.
pro sport 22
Sx225tx
6yr-w0035e200
Wiring to the Guage
Connector #1
Pink/Grey/Black/Orange
Connector #2
Blue W/white stripe
Green
White W/red stripe
Greeen W/red stripe
Wiring to Engine
Grey wire unhooked
All dip switches down
pro sport 22
Sx225tx
6yr-w0035e200
Wiring to the Guage
Connector #1
Connector #2
Blue W/white stripe
Green
White W/red stripe
Greeen W/red stripe
Wiring to Engine
Grey wire unhooked
rodbolt
I dont think the tach is plug and play for that.
let me check and ill post back tonight or tomorrow.
pro sport 22
We did find out that the trim sender switch is bad. Would that affect the temp guage?
