DukesFin
Thread starter- Joined
- Oct 12, 2005
- 504
Okay, the remote tank is not filling the main tank.
1990 Yamaha 150 ETXD
All three LED's lit up and buzzer went off. Shut the motor down and pulled the cowling off to discover the engine/main tank was at the "low" level. Turned key switch back on (buzzer sounding still) and hit the emergency switch and nothing... Got out the reserve bottle of oil I keep on board and manually filled the main/engine tank, turned it back on and was "good to go" for a while... Until it ran low again, refilled the engine tank (tried the emergency switch again to no avail), and brought the boat home.
I read of a troubleshooting guide, but I've searched on here and can't seem to find it.
Any help would be greatly appreciated!
I did pull the float switch out of the main/engine tank with key on and as the float switch "fell" the alarms did sound, placed it back in the tank and (since the tank was full), the alarms turned off.
I noticed that when I turn the key switch on, the pump motor runs ever so quietly. Not loudly like it used to though (when it was filling the main/engine tank)...
Thanks!
Thanks!
