Yamaha Oil Sub Tank Holder
DC20
I just took out the tank to replace the strainer, the holder and bracket are very rusted and breaking apart. New ones are $122.30. Does anyone know of a cheaper alternative or something made out of plastic that will hold up to saltwater?
DC20
Re: Yamaha Oil Sub Tank Holder
I think I will try using a battery tray, it's about the same width I will just need to cut the ends off as it is about 1.5 inches longer. Inexpensive and won't rust...
BruceAML
It would be good if you gave us the year and model of the motor you have.
DC20
2001 Yamaha 130 TXRZ
BruceAML
The part you need is called a holder oil, sub tank. The part has been changed since the original design. The part number is 6E5-21734-01-33. It is $84.92 I hope this helps you.
