Re: Yamaha Outboard Monitoring Device?
yes, its called find a real dealership that can fully,actually should have before the sale, explain to you the advantages of rigging your F150 with command link gauges.
command link can show all engine paremeters as well as sea water temp,depth and speed.
it will flash a maint indicate lamp at your 100 hr intravels as well as set the water detect visual in the event of a water detection while the engine is in gear.
to many dealers dont understand command link or even the importance of the standard digital 6Y5 tach, even the 6Y5 tach can differentiate between oil and temp alarms as well as give critical WOT information.
the command link will also show fuel flow rates in both MPG and gallons per hour for fine tuning trim and trim tab settings or even shifting hull loads.
so for 700 more on your 11K motor you could have had the twin guage square command link package but all is not lost as its still a plug and play option on your motor.
the only drawback is it takes a software engineering degree to operate it
its not hard just not real user friendly but with some play time you can configure it to display a wide array of engine information.
