Yamaha overheat question
Gradywhite3535
I have a 2003 yamaha 130. If the engine over heats for whatever reason would the alarm go off? Thank you
just tested my thermo switch on my yamaha 85 day before yesterday. i removed the switch from the block, placed it in less than an inch of water in a small metal bowl, with the ignition switch on but motor not running, i heated the bowl of water with a wagner electric heat gun and monitored the temp with an infared temp gun, Heat the bottom of the bowl until the alarm sounds and check the temp
