frozenokie
Thread starter- Joined
- Feb 4, 2008
- 309
After this weekend of giving this 97 Yamaha GP760 another tryout, I have experienced something new. I ran it on the trailer while in the water to assure my carb settings somewhat. After I felt good about them, I took off for a test ride. WOW!! She really zips down the lake and after about 15 minutes of riding, whaaaaa... completely died. Then the battery wouldnt even turn it over. Wierd - I just charged that new battery the night before so it isn't that. After floating for about 2 to 3 minnutes, I tried again. Wah, wah, wah, then vroom! Up and out she came again. Zipped down the lake for about another 100 yards, then same thing again, and again, and again!!! And again, the battery "acts" like it's dead - but it isn't. Hmmm...
Then I remembered... when I have been taking her to the pump for fill up, each time when I unscrewed the gas cap... PSSSSSSSSSSSSSS. Out came all the pressure from the shaking of riding on the trailer. Both times filling up it has done this. I'm now thinking that the tank is over-pressurizing while riding and creating a reverse vapor lock for the lack of better terms. Pressure instead of vacuum. Does this seem to be my problem
I can contemplate how the extra pressure may be shutting off my fuel supply at the needle/seat. Then after a few minutes resting, the pressure escapes just enough to get it started again.
I took off the vent supply hose after I got home and blew through it - completely clear and you can hear it thrushing through the check valve. This didn't happen on the maiden voyage a few weeks back. So I'm confused as to where to start looking for the problem. Carb HI/LOW settings are right where the book says they should be.
Am I looking at a "pop-off pressure" issue here?
Any help is appreciated - Even from slag... Dude - no hard feelings by any means
And you too smoofers - you seem to have that kind of experience likewise
