imported_danb
Thread starter- Joined
- Mar 7, 2007
- 2
I have a 1988 200hp V6 Yamaha. Over this season when I shifted into gear it didn't always catch right away, it kind of grinded a little bit before going fully into gear. Recently it started to not even go into gear at all. I was told that it could be the shaft rod because before 1994 the shaft rod was made out of steel, not stainless steel. I gues it will rot over the year and eventually bend when being shifted. I looked at the visible part of the shaft rod and it looks pretty corroted. I was wondering if anyone knows if its possible to change the shaft rod without removing the powerhead. Is there any way to do it by just removing the lower unit. Also is there any other possibilities of what the problem might be. Any info would help. Thanks
