Hey everyone, I have a 1987 Yamaha 70hp 2 stroke ETLH model (auto mixing pump for the gas/oil) and I'm having a starting issue. Bought the boat/motor this year, and I was told it sat for the past 2 seasons. Figured it would give me a hard time but fired up and ran great the first 3 or 4 times out, then began having a hard time starting. I sprayed carb cleaner on the three "gates" of the carbs and it fired up. Now I have to do that every time or it will just crank and crank and never fire. I assume the carb cleaner is just acting as starting fluid (I know to never use actual starting fluid). Tried new gas twice, new primer bulb, new fitting for the portable tank and the line that clips into the motor, tried a different portable tank, new fuel filter, checked all connections/lines and didn't find any leaks or cracks. I just spray the three carb openings every time and it fires right up. Runs great, idles fine, full throttle with no issue, it even starts up after it's warmed up. Not the worst problem, but pretty annoying, and I'm hoping someone has an idea.
