242AbacoGV
- Joined
- Jun 30, 2009
- 6
My question is the following; I have removed the four screws for the throttle control cover to tighten up the throttle as it was falling back on its own in a chop. Can anyone advise me as to what the 2 screws are for with the locking bolts on them on top of the controller. At first I tried to adjust them to tighten the throttle which did not work, only to find the adjustment screw at the bottom of the assembly gave that a 1/2 turn and worked. I tried to eyeball back the 2 screws with the locking bolts best I could back to the original position and re-tightened the locking nuts. One thought I had was these are the adjustment screws on how much pressure is required to place the engine in forward or reverse... Many thanks..
