Yamaha Trim Tilt Switch Side Mount Remote Wire Connection
PeterB26
I have a 703 Yamaha side mount remote on a boat with a 40 HP outboard. The switch became intermittent this spring but the motor mounted switch works just fine. Researching I have found videos of replacing the switch in the remote or simply dismantling it and cleanig it. What I have not found is where a brand new replacement switch plugs into the overall wiring harness. I can see from listing photos of the switch that it has three wires with push in barrel type quick connectors, but I don't see on my wiring harness where they mate to go back to the motor. Can anyone here ennlighten me?
Thanks
PeterB26
boscoe99
The trim/tilt wires are in the ten pin harness from the remote to the engine main engine harness.
PeterB26
Thank you. I see now where the connection is made. It was covered up in my boat but easy to find once I knew where to look.
99yam40
yeah, those bullet connectors are so you can add another switch somewhere on the boat.
I added one on my poling platform, so I could lower the motor while poling in shallow water to stop the boat from moving when I wanted it to stay put while casting at reds I was seeing
boscoe99
Are we talking about the switch in the handle of the 703 remote control box or the connection point for the addition of an optional trim/tilt switch?
99yam40
he did mention bullet connectors, and those were the only ones I knew of on the 703
