yamaha water pressure gauge
nepo
How do i test water pressure gauge on a 02 225 yamaha?
Silvertip
Honorary Supreme Mariner
Re: yamaha water pressure gauge
Start the engine (in the water of course -- not on muffs). If you have a tell tale stream but no pressure reading, pull the tube off the back of the gauge. If you get sprayed with water, the gauge is bad. If not, the tube is pinched or clogged. If you don't have a tell tale stream, the water pump is bad.
nepo
Will the alarm go off if i have a bad water pressure gauge?
Silvertip
No -- but the alarm will sound if you don't have water pressure. Lack of water pressure causes overheating and the alarm you get signals Overheating.
