metriccrescentwrench
Thread starter- Joined
- Oct 22, 2007
- 2,598
I've got a '96 Yamaha WaveRaider 1100 which runs great - for 10 or 15 minutes. Then out of nowhere it just shuts off as though I hit the stop button. It'll crank back up and barely stay running, than after a few minutes it'll run fine.
Compression is great (120 psi on all 3). I've checked the kill switch with an ohm-meter, even went so far as to spray water on it, and couldn't find any issues there. I've checked the spark with a spark tester set at 15 mm as specified in the manual (but of course the engine was cool when I did this test).
To me this seems likely to be a bad ignition box, but I hate just throwing money at a problem. Any input from anyone who's had a similar problem?
